Which Stream Deck ?
So I am about to finally take the leap and purchase a Stream Deck. Looking at the Stream Deck+ or the Mk ll with 15 buttons. Any advice from those of you Flex owners that have either one? Pros and cons? Are the + model knobs useful?
73 & Tnx
Paul w2eck
In my opinion the 15 button model is not going to cut it. There are so many commands that can be used to control the Flex.
Just an example above but when you consider that almost all of those 32 buttons open to other layered commands, I just do not see that the purchase of a 15 button Deck is a wise move.
Erik
So you would go with the Stream Deck + ? At this point I am not sure I understand the fully what can be done with the Screen area in the middle and the knobs?
73 Paul w2eck
Stream Deck XL?
Go with the Stream Deck XL. It has 32 buttons and can have many more by adding sub-pages. After you are well familiar with the Stream Deck, then consider the "+". It has 4 knobs or dials plus 8 buttons. It can have 10 panes selected by swiping on the LCD screen above the knobs.
73, Craig KØCF
Hi Paul, XL all the way for me. Too much faff to mess around with knobs, panes or 15 buttons. Just my experience though, each to their own, and I don't mean to diminish Paul's assertion that the "+" is viable. But 32 buttons gives near instant access to everything the Flex can do and easily with one or two presses.
Craig & Erik
Wow - reosunding votes for the XL- tnx, which is a big price bump up from the other two choices. Would really like to hear from someones experieince with the +, to hear about how they use they use he +'s screen and the knobs with a Flex
73 Paul
Paul,
I really like the Stream Deck + for both its knobs and it's simplicity. Knobs are just a better than buttons for controlling most of the radios functions. There are only four knobs but it's easy to "stack" functions on the knob then cycle through them by pushing the knob (it's a button as well as knob). If you use my Deck Master plugin each knob can control a "choice" or "toggle" as well as "range" type function. So there are many ways to load a lot of functionality onto a single knob.
The XL is too big for my tastes but it does offer a lot of buttons. ...and apoligies if this sounds like a Deck Master infomercial, but Deck Master will let you spread a "range" control out over two or three buttons and still present a clean display of the status of the function. Volume control is an example of a "range" so with the XL there is plenty of room to assign three buttons to that one function. One to raise volume, one to lower volume, and one to return to a preset value. Or skip the preset and just spread it across two buttons.
Dont forget about the Stream Deck Mini... I'm sure there are plenty of folks who would be very happy with just the six buttons of the mini. Or get two, one for each hand. The Stream Deck software will let you connect a number of devices regardless of model.
The choice here is really personal. I dont think there is just one right way to configure the any of the Stream Deck devices. Best advice I can offer is to step back and think about what you really would like to control with buttons rather than the mouse. How often you're likely to press those buttons, how much desk space you'd like those buttons to take up. Both the XL and the SD+ are fairly large. So desk space could be a consideration. Of course, the Stream Deck Pedal doesnt take any desk space. If I could have only one, I'd go with the Stream Deck +.
--Don
Don
Thanks for your info, exactly what I was looking for in terms of the Stream Deck+ could be used. And yes, desk space is a consideration for me.Think I am going with the +, choice. Looking to Prime Days for possible savings.
Paul W2ECK
Don, what are you able to program the dials for on the stream deck +?
Don, what are you able to program the dials to do on the stream deck +? What actions are you calling?
Jay,
When connected to Slice Master, the dials on the Stream Deck + can control just about any (let me know if I missed one) function that shows up in SSDR as a continuous range of values. This includes the frequency setting on your slices. It's also possible to use the dials to scroll through settings that have a fixed set of values. Since the dials also function as push buttons, they can be used to toggle settings on/off too.
The features are all there. It's up to you, however, to assign the functions to the dials and buttons of the Stream Deck.
--Don
Can i use the foot pedal alone without the deck? I am not interested in the controller only the pedal.0
Assuming that you have a 6000 or 8000 series Flex radio. If you are close enough to the physical radio, you can plug the foot pedal directly into the PTT jack on the back of the radio.
If you are operating remotely using SmartSDR, you can wire up a serial port on your computer and use SmartSDR CAT to configure it to be PTT. On most computers these days this will require a USB to RS-232 cable. You configure the port to be keyed by either the RTS or DTR line.
While this does require a small amount of soldering, it is reasonably easy to do.
- 310 Community Topics
- 565 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 384 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 106 FLEX-8000 Signature Series
- 886 Maestro
- 49 FlexControl
- 841 Genius Products
- 433 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 266 Shack Infrastructure
- 187 Networking
- 427 Remote Operation (SmartLink)
- 132 Contesting
- 685 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
