TWO FlexControl
Here is my setup....
http://www.nn4zz.com/Flex6600.htm#FlexControl_setup_to_use_2_knob_with_SSDR
Al / NN4ZZ
Hi Anton, EDIT:
I don't know if that is possible or not.See Al's post, above for how to use two FlexControls with one radio. If not, you can build a TeensyMaestro if you like building things. It will control the first two slices it finds. It has a set of controls for Slice 0 and one for Slice 1. Here is the GitHub link. There is a schematic, bill of materials, User Manual and Builder's Guide posted there.Here is a link to the Flex Community thread:
This is not a beginner's project, but it is not overly complicated either. It is all point-to-point wiring, no SMD components. If you elect to build one, I monitor the TeensyMaestro thread on this community, and am always happy to answer questions.
I just use SDR bridge to control both of mine, works great. No need to set-up anything special, just plug and play.
Rich
Thank you very much, friends, I will try several options that you have suggested! 73!
I have 2 FlexControl. What and where is SDR Bridge with some install and use info? Later for 2 slices, for now, its audio on one and frequency on the other.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
