Maestro "C" sidetone too weak
df4wx
df4wx Member
Hi, the sidetone of my Maestro C (Software 3.7.4) is too weak when using the internal keyer with a paddle or a straight key. I know how to set the sidetone level and it is already set to 100%. Nevertheless, when the band or the environment is noisy, I would prefer to have a much louder sidetone.
I could turn down a loud sidetone to a comfortable level, but currently I am lost in loud environments.
Is there a way to increase the sidetone level?
    The Speaker in the Maestro is pretty small. What if you used powered external speakers.
    The speaker audio is pretty audio, but likely not enough in a noisy environment. To try to drive it with more power will likely cause distortion.
    I gather you can't use headphones?
  • df4wx
    df4wx Member
    Hi, thanks for your comment. This would help in a loud environment. As an external speaker cannot distinguish between the signal and the sidetone, the SNR would not be changed.
    In fact, the receiver output is much louder than the sidetone, even with 100% sidetone level.
    You might try resetting the radio and see if that helps.
  • sm6bga
    sm6bga Member ✭✭
    I have the same problem. I have reset the radio but no difference.
    I think it came up when I upgraded to version 3.7.4,
    but I don't want to downgrade.
    Any suggestions what to do ?
    Hans SM6BGA
  • df4wx
    df4wx Member
    Hi,
    the problem is an issue of the Maestro, not of the radio. The sidetone is generated locally and then fed into the audio stream. I believe, a software upgrade with different settings of the audio mixer could solve the issue.
    73 de Micha, DF4WX
  • sm6bga
    sm6bga Member ✭✭
    Perhaps they changed the settings in version 3.7.4
    Please change back !
    Hans SM6BGA
  • F4BPO
    F4BPO Member ✭✭
    no news ?
