Smartlink and Spectrum
I am trying to help a fellow ham get his smartlink working. He was able to get the Smartlink account setup and get the radio registered. However, when you click on the Test button, it turns red. We can see his radio show up on iOS over the internet/cell network, but it won't connect. I am assuming that we need to manually setup the port forward on his Spectrum router. The problem is, we can't seem to figure out how to log into the router. There is no sticker or anything on the router that gives the login information. Only for the WiFi login. I forgot the model of Spectrum router he has but it was installed around 2021. I just need to know the login info. Does anyone have Spectrum and know what the default credentials are? I have tried all the obvious stuff (admin, admin....admin, password...admin and then no password) and can't get logged in.
There is an app you can download on your iPhone or Android but it just has basic settings and nothing advanced link port forwarding.
Burch
K4QXX
You need to key the transmitter from the remote shack... Get somebody to do that.
Burch
The next steps are. They look a bit confusing, but it really isn't.
- figure out how to log into the Router
- Is the IP address the ISP provides CGNAT'd? https://www.purevpn.com/ca/blog/how-to-check-whether-or-not-your-isp-performs-cgnat/
- If you can't log in, does the Router have uPNP turned on? (BTW, you can test to see if the router is configured correctly by running a program called UPnP Wizard. https://www.xldevelopment.net/upnpwiz.php
- BTW, if you look in the bottom left of the UPnP Wizard, you'll see the external IP address.
- Look for a line starting with FlexRadio - you can see I have 4 lines as I have 2 radios.
You can always open a support ticket. It is free.
Thanks for the replies. I guess I didn't explain my issue well. The transmitter has been keyed and the radio/smartlink has been registered. I can see the radio through the internet. I just can't connect to it.
Mike, I can't connect to the router as I don't know the login and password. That is really my issue. I have instructions from Ken on how to manually setup the port forward but until I can get into the router, I can't do that.
I do not think the ISP does CGNAT but I will check the IP address with the link you sent and will also check on the uPNP. Thank you for those suggestions. I will report back when I can remote back into his computer.
Burch
Mike, I was able to verify that the ISP is not using CGNAT and I ran that software to check on UPnP and got an error message. "An error occurred while discovering the UPnP device. Please verify that UPnP has been enabled on your router and select the correct Binding IP associated with your router". So, I am assuming this is why the port forward didn't get added to his Spectrum router automatically. And since I don't know the login info for the router, that is a problem.......
Burch
Apparently, Spectrum won't let you log into their "rented" cable modem/router. My friend called their tech support and they put in the port forwards. Unfortunately, we gave them the incorrect TCP port and had to call back and got a different tech who didn't know what they were doing. He is going to call them back again today so hopefully we can manually get the ports configured.
Burch
What did the uPNP wizard show?
I can log into my Spectrum router using the spectrum mobile app and do port forwarding etc.
I answered that above yesterday.
He got it working. Called Spectrum again and they redid the port forwards and I was able to log in to his radio from my iPhone. Glad I don't have Spectrum!
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
