Half space tilde has no effect in N1MM+ using SSDR 2.6.1 with 6300
Michael Ruttenberg
When I am using the current version of N1MM+ (1.0.8230) with SSDR 2.6.1 (Windows), and I set my CW macro to G7~TWC, it sends G7TWC without the half space. This gets misread as a GM station. The half space used to work, on v1.x of SSDR and early versions of v2.x.
Page 236 of the N1MM+ documentation shows it should send the half space.
I raised this with N1MM+ as a bug and got a reply from John K3CT who says it's working for them with Winkeyer, and suggests I raise this with Flex.
I see someone raised this for v1.x but that is many years ago, and I didn't have this issue then.
Any ideas? Can anyone replicate this?
G7TWC
G7TWC
I'd like to understand how N1MM is mapping this. I noticed that Winkeyer does map '|' for a half dot space, but that seems to be different than the desired timing here (half word?). If someone that understands the technical details of this could send me a note directly (eric AT flex DASH radio DOT com), I would appreciate it. Thanks.0
Half word? No, half space. I’ll email you off list re N1MM comms link. Mike G7TWC0
Between Michael and John K3CT, we were able to figure out what needs to be done on the FlexRadio side to make this work. For tracking purposes this is #J7959. Thanks for the heads up on this.0
Has this issue been addressed? Operating today with N1MM, I can't see that the ~ character has any effect when using N1MM with the internal keyer in my Flex 6600. I am using SSDR 2.12.0.
Tim K9WX
I just checked on this and the change has not yet been implemented. I will raise this in our defect review meeting this week though. Thanks for checking on it.
Does this apply to SSRD v.3 as well? TIA.
Yes. We haven't implemented support for the half space in any version (yet, as of v3.7.4).
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
