SmartSDR version 3.7.4 update on Radio Tab in SmartSDR isn't showing up as an option
SmartSDR for Mac is not a Flex product. Its version numbering system does not match that of Flex products.
Correct the SmartSDR macOS is version 2.9.12 and is not related to the firmware question. When I enter the Flex setting menu radio tab I am currently running vs 3.7.3. I select check for upgrade and the most recent upgrade available is 3.7.3. It does not show 3.7.4 available as an option. The Maestro C is showing that 3.7.4 is an update option. So question is does the radio upgrade if you select the new version on the Maestro or is that to select which version to run the maestro under. Or perhaps while Flex just announced the release of 3.7.4 did it not roll out as an upgrade option on the radio yet?
Ended up being an easy upgrade. Just selected the update on the Maestro C and it upgraded both the Maestro and the radios firmware to 3.7.4.
3
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
