SmartSDR version 3.7.4 update on Radio Tab in SmartSDR isn't showing up as an option
I am running a Flex 6400 using SmartSDR for macOS and a Maestro C. When I click on the update tab in the radio window on SmartSDR there is no version 3.7.4 showing as available. On the Maestro C when it turns on I have a choice to upgrade to 3.7.4. Is the upgrade done using the Maestro? If so do I follow all the usual upgrade steps of rebooting -"power cycle" the 6400 prior to selecting 3.7.4 on the Maestro C. Thanks for any help.
  • Neil D Friedman N3DF
    SmartSDR for Mac is not a Flex product. Its version numbering system does not match that of Flex products.
  • WB2RRF
    Correct the SmartSDR macOS is version 2.9.12 and is not related to the firmware question. When I enter the Flex setting menu radio tab I am currently running vs 3.7.3. I select check for upgrade and the most recent upgrade available is 3.7.3. It does not show 3.7.4 available as an option. The Maestro C is showing that 3.7.4 is an update option. So question is does the radio upgrade if you select the new version on the Maestro or is that to select which version to run the maestro under. Or perhaps while Flex just announced the release of 3.7.4 did it not roll out as an upgrade option on the radio yet?
  • WB2RRF
    Ended up being an easy upgrade. Just selected the update on the Maestro C and it upgraded both the Maestro and the radios firmware to 3.7.4.
