Spots in to Maestro ?
I am new to a Maestro and learning some of the intricacies. I’m trying to understand the ways “spots” can be sent so that they appear in the Maestro panadapter . I use Smarsdr for Mac, sometimes SSDR for Windows , and sometimes SSDR for iOS . It seems that spots that I see on my computer screen do not always make it over to the panadapter on the Maestro C. Case in point : Lots of spots made it over tonight from the CW portion of the band but none from the Phone portion ( the computer panadapter running SSDR Mac shows spots from the Phone section of the band ).
Andy K3UK
Hi Andy,
Congratulations on your new Maestro !
There are two things I can think of related to your question: 1) sometimes the software you're using to send spots filters them so only those that survive the filter criteria are sent. So you might check that software accordingly. I use Spot Collector from the DXLab Suite. It is easily the most powerful spot source software there is. That's partly because of its powerful spot aggregation and filtering capabilities and in my case, most of the spots it ingests intentionally don't survive to my Flex displays (including Maestro).
2) Notice in the "Spots" tab in the Maestro settings that you can adjust how many rows of spots are displayed. And notice in your screenshot here that "+3", "+5" and so on are displayed. Those indicate spots that did make it to your Maestro but are not shown because of that setting. If you select it by touching it, you'll see them. Obviously, the screen can only display so many so eventually with enough spots that indicator will appear no matter what your setting. That's a good reason FOR filtering your displayed spots by the way. Try to filter them so only the ones you actually care about are sent to the Flex in the first place. Hope that helps !
Russ KR6W
Thanks Russ, I am a long time Spotcollector user but mostly have switched to SmarSDR for Mac these days and don't use Spotcollector as much. I think filtering is an issue that I have to investigate more but as far as I know I don't have aggressive filtering on at the moment. It seems that sometimes the Maestro receives spots from SmartSDR for Mac and sometimes it does not. I often run MacLoggerDX simultaneously with SmartSDR for Mac and I am still trying to figure out where the spots that do show up in the C are coming from.
Andy K3UK
Hello guys,
I'm a new FlexRadio owner and I'm still getting familiar with this amazing machine. I have a 6600 with Maestro. I really want to be able to view Spots in Maestro, but I don't use N1MM, but Log4OM. I've seen some comments online from other colleagues who are successfully using Log4OM Clusters. Could you give me tips or guidance on how to achieve this feat?
Thank you very much!
Eduardo PY2VR0 -
Home:
Flex-6500 -> Switched onRemote:
Maestro console (A)
Computer -> Not switched on, SMART SDR not started.How does the (remote) Maestro console display the DX cluster?
Daniel
HB9DDS
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 278 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
