Maestro B doesn"t see my in-house wifi6 router!
Has anyone encountered this problem??
Please contact me for discussion. Thanks! de Paul NJ6U
I believe you will need to go into settings and put your router into Legacy mode. This should allow your Maestro to see your wifi.
Yes the Maestro B has an older WiFi version (I do not know what it is) that will not connect to the newer WiFi version (don't know what that is either 😊). This is the reason among others I upgraded to the Maestro C. As the reply says above you need to put the router into legacy mode in order for the router to see the Maestro B. I ran it like that for a year with no issues with my EERO router.
Are there any special characters in your SSID name?
Mike-VA3MW: No, just upper and lower-case letters.
Curt_AC9HO: I tried to find "Legacy Mode" but failed. I'm using an Archer AX10000 wifi6 router.
My thanks to you and Mike VA3MW for responding! 73 de Paul NJ6U
Paul, you might wish to open a support ticket. It sounds like your router is not seeing the typical WiFi modes (802.11bgnAC)
That's probably the best idea! As I've never done that before, could you please point me in the proper direction? Thanks, Paul NJ6U
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 124 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 698 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
