Maestro B doesn"t see my in-house wifi6 router!
Has anyone encountered this problem??
Please contact me for discussion. Thanks! de Paul NJ6U
I believe you will need to go into settings and put your router into Legacy mode. This should allow your Maestro to see your wifi.
Yes the Maestro B has an older WiFi version (I do not know what it is) that will not connect to the newer WiFi version (don't know what that is either 😊). This is the reason among others I upgraded to the Maestro C. As the reply says above you need to put the router into legacy mode in order for the router to see the Maestro B. I ran it like that for a year with no issues with my EERO router.
Are there any special characters in your SSID name?
Mike-VA3MW: No, just upper and lower-case letters.
Curt_AC9HO: I tried to find "Legacy Mode" but failed. I'm using an Archer AX10000 wifi6 router.
My thanks to you and Mike VA3MW for responding! 73 de Paul NJ6U
Paul, you might wish to open a support ticket. It sounds like your router is not seeing the typical WiFi modes (802.11bgnAC)
That's probably the best idea! As I've never done that before, could you please point me in the proper direction? Thanks, Paul NJ6U
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 150 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 938 Third-Party Software
