My Maestro B doesn"t see my in-house wifi6 router. W6GMU
Correction: My Maestro B sees 3 wifi items, but not my in-house wifi6 router. My Maestro A sees everything.
    The A and B model use different WiFi modems. It is possible they are configured differently by engineering.
  • PAUL GUSSOW
    PAUL GUSSOW Member ✭✭
    Thanks for that info, Mike! BTW, my call is now NJ6U. I did more testing yesterday: The Maestro B doesn't see my AX10000 wifi6 router via wifi...same result if I plug it into the router! When plugged into a router port, it sees 9 more networks. My Maestro A sees the router perfectly + 5 local networks [the B sees only 2 local networks when not plugged into the router. Any ideas, Sir??
