FlexButtons V2.3
I've released another version of FlexButtons (V2.3) into the wild.
If you use CW/SendText FB can generate a local sidetone. This may help with some of the sidetone issues.
A new button Cosmetic/Session allows you to make a button to switch sessions.
The appears to be an anomaly in FlexLib that makes it think the CW speed is 30 wpm and this prevents FB from setting the speed to 30wpm, so if you set it to 30 wpm I change it to 31 wpm. That solves the problem until I get a better solution.
There are a few more checks to prevent error conditions.
TU, I just updated to this version. I think you might have the commands for the WNB and Mute mixed up. No problem fixing it locally but I am bringing it to your attention in case you want to modify the download copy.
Hi Keith, I struggled a bit with the CW speed and some other parameters in the Flex API. The solution is to do a bind to the GUI client. Once you are bound, you have proper access to CW Speed, RF Power and some others.
It looks like you are using FlexLib with ,net in your app. Here is a slightly out-of-context example, but it may help:
_thisRadio.BindGUIClient(client.ClientID);
John, I thought I fixed that. I'll check it out. Thank you.
Len, I had avoided doing that because I wasn't really a GUI client in my vision of things. It sounds like a reasonable answer to my problem - thank you!
Hi Keith, You're right, you are not the GUI client, SmartSDR or a Maestro is (i.e. anything that brings back the panadapter and waterfall). The idea is that you bind your non-GUI client to the GUI client so that you can accurately show TCP items like CW Speed that can be different on each GUI client.
- 387 Community Topics
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 944 Genius Products
- 809 Peripherals & Station Integration
