FlexButtons V2.3
I've released another version of FlexButtons (V2.3) into the wild.
If you use CW/SendText FB can generate a local sidetone. This may help with some of the sidetone issues.
A new button Cosmetic/Session allows you to make a button to switch sessions.
The appears to be an anomaly in FlexLib that makes it think the CW speed is 30 wpm and this prevents FB from setting the speed to 30wpm, so if you set it to 30 wpm I change it to 31 wpm. That solves the problem until I get a better solution.
There are a few more checks to prevent error conditions.
TU, I just updated to this version. I think you might have the commands for the WNB and Mute mixed up. No problem fixing it locally but I am bringing it to your attention in case you want to modify the download copy.
Hi Keith, I struggled a bit with the CW speed and some other parameters in the Flex API. The solution is to do a bind to the GUI client. Once you are bound, you have proper access to CW Speed, RF Power and some others.
It looks like you are using FlexLib with ,net in your app. Here is a slightly out-of-context example, but it may help:
_thisRadio.BindGUIClient(client.ClientID);
John, I thought I fixed that. I'll check it out. Thank you.
Len, I had avoided doing that because I wasn't really a GUI client in my vision of things. It sounds like a reasonable answer to my problem - thank you!
Hi Keith, You're right, you are not the GUI client, SmartSDR or a Maestro is (i.e. anything that brings back the panadapter and waterfall). The idea is that you bind your non-GUI client to the GUI client so that you can accurately show TCP items like CW Speed that can be different on each GUI client.
- 331 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 180 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 166 FLEX-8000 Signature Series
- 911 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
