PTT options
I am using the RadioSport hand PTT switch with right angle RCA to 3.5mm adapter.
I made my own "thumb-Switch" with a spring-return center-off toggle switch mounted in a "Tic-Tac" mint case. Then scrounged up an RCA cable from an old VCR and used that to connect to my FlexRadio.
In order to use it with my Maestro, I use the Right-Angle RCA to 1/8 inch mono adapter.
I made another thumb-switch using a push-button switch mounted in a 4-inch length of PVC pipe.
Both switches work great.
For a footswitch, I use an industrial cast aluminum footswitch that I got from eBay. They were 2 for $16 when I bought them 10 years ago. I still haven't broken the first one. I wired it up to my own RCA Cable.
TEMCo Aluminum Foot Switch 10A SPDT NO NC Electric Power Pedal Momentary New CNC | eBay
I 3D printed one,
It uses a Keyboard switch so should last a LONG time
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 294 FLEX-8000 Signature Series
- 969 Maestro
- 941 Genius Products
- 345 Tuner Genius XL
