FRStack and swap
I have been unable to get FRstack to swap slices. Seems easy enough. Right click on one slice in the FRstack software and chose swap with. Nothing seems to happen. Running the latest FRstack with 3.7.3 SmartSDR.
Am I missing something?
Hi Rich, it works for me, but it is a left click, not a right click.
Yea Right click. Do you have mouse setup left hand? Attached is what right click gets me.
Oh, I see...
That doesn't work for me either. I just left click the slice I want, and it sets that slice to active and TX enabled.
Len, KD0RC
I am wanting to SWAP the frequency and other info from one slice to the other.
Common with many radios. Even Flex has A<>B on the M radios.
I assume it should work on FR stack but is not. I need to see if the REST command on my stream deck works with FRstack
The swap slices menu doesn't work on my 6400 either0
I fixed this issue, I will release an update soon. 73, Mark W3II
Thanks Mark!
FRStack V3.7.38.75 has been published.
Close FRStack then relaunch FRStack, you should be prompted to download latest release.
Mark thank you. Was just coming here to say I downloaded and works great.
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
