FRStack and swap
Rich McCabe
Rich McCabe Member ✭✭✭
edited February 2024 in Third-Party Software
I have been unable to get FRstack to swap slices. Seems easy enough. Right click on one slice in the FRstack software and chose swap with. Nothing seems to happen. Running the latest FRstack with 3.7.3 SmartSDR.
Am I missing something?
    Hi Rich, it works for me, but it is a left click, not a right click.
  • Rich McCabe
    Yea Right click. Do you have mouse setup left hand? Attached is what right click gets me.
    Oh, I see...
    That doesn't work for me either. I just left click the slice I want, and it sets that slice to active and TX enabled.
    Len, KD0RC
  • Rich McCabe
    I am wanting to SWAP the frequency and other info from one slice to the other.
    Common with many radios. Even Flex has A<>B on the M radios.
    I assume it should work on FR stack but is not. I need to see if the REST command on my stream deck works with FRstack
  • otisw
    otisw Member ✭✭
    The swap slices menu doesn't work on my 6400 either
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    I fixed this issue, I will release an update soon. 73, Mark W3II
  • Rich McCabe
    Thanks Mark!
  • Mark_W3II
    FRStack V3.7.38.75 has been published.
    Close FRStack then relaunch FRStack, you should be prompted to download latest release.
  • Rich McCabe
    Mark thank you. Was just coming here to say I downloaded and works great.
