Sound and Mic through car Bluetooth
Is there a way to get the audio and mic to work through the blue tooth on my car and truck. my music and phone work through blue tooth but the IOS SmartSDR does not.
Walter, 73 W9KJO
  • K3SF
    K3SF Member ✭✭✭
    I assume the iphone works with car via BT uasing carplay...
    but first does smartsdr-ios on the iphone work with your car?
    and
    is your question about ipad running ios and smartsdr??
    little hard to understand your situation without more detail...
    Paul K3SF
  • w9kjo
    w9kjo Member ✭✭
    Yes it is an iphone and it works using Car Play. I have not tried an ipad yet.
    Walter, W9KJO
  • Rick_KJ5WO
    Rick_KJ5WO Member ✭✭
    Hi Walter, sorry for the slow reply. It worked last year but not this one. I believe that additional sound options have been added. I had to make sure 'Audio Device' is checked for the vehicle and then I disable 'Default to Speaker' below that and mine is working fine.
    Hope it helps!
    Rick…KJ5WO
  • w9kjo
    w9kjo Member ✭✭
    Problem Resolved
    I did not realize I had feedback through my home station mic at the time. The feedback was heard on the iphone audio. When I realized the feedback and corrected it the iphone cleared up.
    Who knew the station audio affect the remote audio.
  • WV9L
    WV9L Member ✭✭
    I used the factory handsfree in my Chevy Colorado for years with my iphone or ipad to do SSB while commuting. It works well. Just go up to the gear in the upper left of the app and select audio device. Then select the vehicle device in the list. Works great. My new Jeep Wrangler is a lot noiser in the cabin, so i now have to use a single airpod if i want to use it while commuting.
