6600M front speaker issue
Well here is one for everyone.
I get interference when using other rigs in the shack.
the rig has power but not turned on.
If i tx on the 5110 or yeasu 101 the speaker makes strange noises
but if i turn on the 6600m there is nothing, just turned on no front panel or sdr running.
drove me crazy finding it.
it's like Rf getting into the rig. but my Rf meter a greefkit lol shown nothing even when turn up.
Nothing else is doing this.
Rob K8YV
We would need to know more about your setup, but it sounds like you have RF in the shack when you should not.
Are you using an EFHW antenna? If so, does it have a counterpoise outside that is greater then 1/4 wave of your lowest operating frequency. This is required, regardless of what anyone says, to ensure the RF stays off the coax.
It is also a good idea to have chokes on the feedline from the antenna.
If this isn’t your issue, it might be a ground issue (no ground or floating ground).
That is some of the more common solutions.
Hi Rob, to add to what Mike said, start unplugging things from the 6600M one by one until the problem stops. This will likely be the entry point of the RFI.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 962 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
