MAC Low RF Power - 40m and 15m
Something new today...
- MAC will NOT tune 40m and 15m,
- Windows WILL tune 40m and 15m
Until today everything was working great.
Software all updated.
Windows SmartSDR, 3.6.8
Mac: 2.9.09 (240401)
Ant. Genius 8x2: 4.1.7
Tuner Genius 3x1: 1.1.20
Power Genius: 3.8.4
Any suggestions? No, I will not stop using MAC SmartSDR.
Thank you,
Birton - N6UG
MacBook Pro M2, OS version Sonoma 14.3.1
Windows version, Windows 11
MacBook Pro Memory: 64gb
MacBook Pro Available Disk Space: 638.68gb
IOS SmartSDR WILL tune 40 and 15m.
PTT inhibit is NOT enabled for any band.
Tune power is set to 30watts
I have removed and reinstall MAC SmartSDR and saw no changes, still will NOT tune on 40 and 15m.
This has nothing to do with it being on a MAC or anything associated with your Mac. They are mutually exclusive as you have found out.
- It would be good to know what exactly happens when you say, it won't tune. What message do you get? Make sure your tune power is at least 20 watts.
- What is the antenna you are using - tell us more
- Does it tune into a dummy load?
- If it is an EFHW, do you have any chokes on the feedline at least 1/4 wave away from the antenna from your lowest operating frequency? This prevents RF from feeding back into the tuner and affecting SWR readings.
Mike,
Problem solved, performed a client ID reset per Marcus. All good now!
Have I mentioned lately how impressed I am with Marcus software and support?
Must be the best "Radio" software/customer support I've ever seen.
Thank you for the comments,
Birton
Thanks!
Share that with your friends and on eHam. It really helps us.
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
