Flex Buttons V2.2
Flex Buttons V2.2 released
This update has a few small changes. It updates FlexLib to 3.6.8.
Keith (K7KAR)
AFGain has changed to allow you to either set a specific value or to adjust the gain by a small amount. If you have existing AFGain buttons, you'll have to redo them as one more parameter is added to the command.
Shrinking/expanding the window. By right clicking on the menu bar you can get rid of the title bar and the menu bar leaving just a small bar at the top. Right clicking on that small bar will return to the original look. This is useful if you are placing FB over your SmartSDR window.
Several dll's were updated by Flex and those have been added here.
Thanks Keith!
Have you considered adding HotKey support (aka, mapping a keyboard key to a function?).
Are you thinking function keys F1, F2 etc. or any key? It's easy to send a keystroke to a specific program (eg N1MM), but if you just send it the keystroke goes to the window with focus which is FlexButtons and isn't too helpful.
Or were you thinking the other way...use keyboard keys to invoke FlexButton functions? The difficulty there is you have to get the focus to FB. If you click something is SmartSDR then hit F1 - it goes to SmartSDR not FB.
got it! thanks
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
