Spurious Emissions?
Anyone have an idea what this could be? Running JS8Call at about 30w with SWR at 1.5...curious why the transmission lower than the tx frequency.
All of those spikes on either side are when I TX. This was FT8
Ensure that you are not over-driving
Note though that those 'spikes' are at a very low level and probably not being transmitted. Check this by putting your radio into Full Duplex (FDX button, lower left) and open a second panadapter. Select the RX A receiver (no antenna connected). Transmit the FT8 sig into a dummy load. The second panadapter can be zoomed in or out to give you a good look at the signal. This will be a much better representation of what you are actually transmitting.
Because FT8 messages are transmitted using frequency shift keying, the visual representation does not keep up with the carrier signal variation and everyone will see some of these spikes. If you are not over-driving and not actually transmitting them then it is all ok. The paper "The FT8 and FT4 Communication Protocols" by K9AN and K1JT on the WSJX web site provides a complete explanation.
Long answer short: just ensure you are not over-driving and if not do not worry.
Thank you very much for the detailed response. What would be a normal TX level setting? I brought the DAX TX level way down to around 25 or so and it seems to take care of the issue, but want to be sure what the signal looks like on the other end
For me, the TX Stream setting is 48. There are some more knowledgeable elmers on here who can confirm or correct. 48 gives me the level seen in the picture.
Paul
Can you show the entire SmartSDR screen please including the antenna selections and the scale on the right side of the Panadapter. Without the scale, it doesn't really tell us much.
Your audio level is too high is the first thought. Dial it down a bit.
- 391 Community Topics
- 665 The Flea Market
- 170 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
