Signal or audio changes when dragging the panadapter
I wanted to attach a video of this happening, but it didn't work for me.
When dragging the panadapter, when it gets to a certain point, a weak signal all of a sudden, becomes loud. I've noticed this several times in the past, but the audio nearly knocked me out of my chair this morning when it got to that point. It's almost similar to inserting a preamp.
I don't believe anything is wrong with the radio, but I'm curious if anyone knows the "why".
Thanks es 73
Ken - W4CCZ
Most likely you are dragging past a band edge, and the preselector is being turned off.
Per W4TME:
"When viewing a panadapter, the SmartSDR software knows how much spectrum you are viewing and if what is being displayed is less than the preselectors filter bandwidth, then the preselector is automatically engaged. If the pandapter is too wide or you have another panadapter that is using the same RX antenna (and consequently using the same SCU) but it is on a different band then the preselectors are disabled.
So if you see the word WIDE displayed in the top right-hand corner of a panadapter, then the preselectors are not enabled."
Also, your RF Gain settings are saved with each band, so when you drag out of the ham band to a general receive area, the preamp could actually be changing.1 -
Your comment brings up another question: I see "WIDE" when sitting on the 40 meter CW portion. If that means my preselector is NOT engaged, how do I turn it on ?
Perhaps I am being thick but surely (?) WIDE appears if the displayed spectrum of the Panorama exceeds the width of the band preselectors. Just zoom in until the Pan is no longer in wideband mode.
These should help. It is also applied to the FLEX-6600
From here:
Thanks, Mike. That explains it all.
- 657 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
