DAX will not show any TX options for WSJTX
DonD
DonD Member
Win 11, SmartSDR/Dax/Cat 3.6.8
CAT works. PTT Works. Setting up WSJTX. Decode works fine. RX is set to DAX RESERVED AUDIO RX 1. In the drop down menu to choose TX there is no TX option. DAX TX STEAMING IS BLUE. MIC STREAM IS BLUE, RX STREAM US BLUE. Flex keys for emit but no audio. How do I enable the TX function to show in the dropdown. Thanks
  • km8v
    km8v Member ✭✭
    edited February 2024
    You don't have an option for "DAX Audio TX" in the dropdown in WSJT-X? There's only one, it's not numbered like the RX DAX devices.
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    Do not use any "DAX RESERVED AUDIO" port. It says "reserved" for a reason - it is only to be used by SmartSDR for internal functions. Instead, use the DAX Audio RX 1 (or 2, 3, etc.) as shown by KM8V for interfacing to other software.
    73, Craig KØCF
  • DonD
    DonD Member
    Thank you both for the answers. The issue is I do not see any choice for "TX". The screen shot shows my dropdown (in two parts) from the WSJTX menu (Settings>Audio). I have uninstalled and reinstalled both SmartSDR 3.6.8 as well as WSJTX 2.6.1. I have successfully run the Flex/WSJTX/SmartSDR in the past on this radio, but the radio has been factory reset since that time so I am starting from scratch again. This is also Win11 now running on a new laptop. Please see the screen shots. Thanks Don
    Hi Don, submit a helpdesk ticket. Flex Support will know what to do.
