DAX will not show any TX options for WSJTX
Win 11, SmartSDR/Dax/Cat 3.6.8
CAT works. PTT Works. Setting up WSJTX. Decode works fine. RX is set to DAX RESERVED AUDIO RX 1. In the drop down menu to choose TX there is no TX option. DAX TX STEAMING IS BLUE. MIC STREAM IS BLUE, RX STREAM US BLUE. Flex keys for emit but no audio. How do I enable the TX function to show in the dropdown. Thanks
You don't have an option for "DAX Audio TX" in the dropdown in WSJT-X? There's only one, it's not numbered like the RX DAX devices.
Do not use any "DAX RESERVED AUDIO" port. It says "reserved" for a reason - it is only to be used by SmartSDR for internal functions. Instead, use the DAX Audio RX 1 (or 2, 3, etc.) as shown by KM8V for interfacing to other software.
73, Craig KØCF
Thank you both for the answers. The issue is I do not see any choice for "TX". The screen shot shows my dropdown (in two parts) from the WSJTX menu (Settings>Audio). I have uninstalled and reinstalled both SmartSDR 3.6.8 as well as WSJTX 2.6.1. I have successfully run the Flex/WSJTX/SmartSDR in the past on this radio, but the radio has been factory reset since that time so I am starting from scratch again. This is also Win11 now running on a new laptop. Please see the screen shots. Thanks Don0
Hi Don, submit a helpdesk ticket. Flex Support will know what to do.
- 324 Community Topics
- 588 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 392 SmartSDR for Mac
- 258 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 12 Aurora
- 148 FLEX-8000 Signature Series
- 904 Maestro
- 50 FlexControl
- 862 Genius Products
- 304 Tuner Genius XL
- 114 Antenna Genius
- 272 Shack Infrastructure
- 192 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 711 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 935 Third-Party Software
