Obscure question about FM deviation
Hi all,
When I am running my transverter for 2 meters, I cannot seem to get a decent deviation level. People have noted that the audio level is weak. Mic is a Heil ProSet Elite, HC6. Even running the mic level at 100, and a few attempts at messing with compression, and I haven't tried turning the equalizers up more than the default, but can't imagine having to do that, something is off somewhere.
The mic audio works FB on SSB. and normally runs around 60, so I know it works normally. It also works for APRS and Packet on 2 meters - Digu-SSB
    Answer ✓
    Hi MIchael
    Not the Mic Gain setting. That is different for every operator. The way you tell what it should be set to is by watching the level meter.
    This should be peaking to just below 0db.
    Have a look at this video right at the point that I set it for. About 2 minutes in. It explains the Mic gain.
