PGXL Rack mount options
I would like to keep the front of the rack looking ........well, more like an equipment rack rather than just a shelf with equipment on it
Jeff
AA0ST
I have a question for Power Genius XL owners who have bought the (somewhat pricy) rack mount kit.
The question is this: does the rack mount kit need to be attached at the rear of the rack or just using the four screws at the front?
My rack is not as deep as the Power Genius and it will stick out the back by a few inches. If the mount is only attached at the front then I'm OK otherwise, I'll just buy a 4U shelf instead.
Thanks in advance!
David G4NRT / Z21NRT
I have mine attached only from the front. It seems fine. If you are worried you can always put a cross bar at the back of your rack to support the PGXL shelf.
I must admit, I was presently surprised by the quality of this kit. Having looked at the usual rack mount shelves and hardware I normally use, this thing is in a whole other league. Think NASA engineered as compares to a shade tree mechanic. (I suppose every culture in every continent has those right?) It is made from strong aluminum, had great machining for the threads had all the parts needed and it fit together as shown in the directions with no hassles. OH, by the way, there is written instructions on how to assemble it, not just pictures.
NOW, if they would just make one for the TGXL my rack would look soooo much better.
Hope this helped.
Jeff
AA0ST
Thanks Jeff! It's all I needed to know!
I'd be happy just to get my Tuner let alone a rack mount for it!!
73, David
Hey, David!
I have just been told my tuner is at the shop, (ML&S). I hope you in the same boat now! Just have to fork out the balance..
73 Mike G4GWH
I used a standard rackmount tray and not relying on just the front screws, I added supports attached to the bottom/back of the tray so it will handle all the weight. Could have used wood but I have a bunch of 1 1/4" square tubing, just cut them to size, cheap solution.
I do not yet own the amplifier, I bought the rack mount to have my rack set up and ready for the plunge with buying one. I will say it looks good, BUT...
I feel like it is not very strong to hold the heavy weight of the amplifier. There is ONLY 6 total small screws that hold the entire shelf to the face plate, the face plate is what is connected to the rack mount. Seems a little light weight to me.
As FLEX does not make a rack mount for the tuner I went to a third party to get one and I will say IT is heavy duty and seems much much stronger than the flex shelf for the much much heavier amplifier.
I may have to buy a third party rack mount shelf for the amp, I just don't want it breaking and falling when I buy it.
I use a repurposed COMPAQ server cabinet.
I bought four 4 post ventilated shelves sold by Star Tech from Amazon. The equipment sits on the racks with ventilated doors closed. AG is mounted to back edge of one shelf. Plenty of airflow around equipment to keep things cool. I mounted the amp on top shelf since hot air rises and it is the warmest pieces of equipment when operating.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
