Issues with Radiosport headset and Maestro
Hi All,
I have an issue with my Radiosport headset in combination with Maestro.
Headset is connected to M-MIC2.
When I push PTT, the spectrum indicates something and if I enable MON there is a humming sound. But no modulation, no power out/carrier is indicated. See picture.
Yesterday it worked just fine when I tried the same settings as I have now.
- Running remote
- RadioSport WIDE M350-ADJ mic profile (worked Yesterday)
- BIAS off
- +20db gain off
- When using the FHM-2 hand mic, connected to M-MIC1 it works perfect.
Any ideas what to try next?
73 de Adde, SM0SHG
This seems normal and is just a minor amount of noise. I see the same thing.
As you have noticed, no RF is emitted.
I don't think it is anything to worry about and is just optics. But, if you are concerned, please open a support ticket.
Hi Mike,
I might been a little unclear. The problem was that I could not get any modulation out. But problem i solved, thanks to the crew at https://pileupdx.com/ I had the wrong cable between headset and the Maestro. Now it works great. I can finally use my nice headset! :D
Ah, sorry, I missed that. Glad you got it sorted out.
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
