Ok to Uninstall old versions of SmartSDR?
Today I fired up "Installed Apps" on my Windows 11 system to clean up some stuff I no longer use. Along the way I noticed 6 installations of SmartSDR going back to my first, 3.3.33. Is it safe to uninstall old versions?
BTW I also noticed that the older versions averaged about 85-90MB in size while 3.6.8 is 420MB. Wow!
Thanks and 73
-Brian n8wrl
Best Answers
    Answer ✓
    Yes, Just don't delete the VSP parts when it asks you.
    Answer ✓
    Yes to this
    Yes to the administrator question
    Yes to this
    Yes to this (I forgot about this one)
    (don't hit NO--- I just did - working too fast again)
    The fix is to just reinstall 3.6.8 (or the most current version)
    Yes to this. But if you are uninstall a bunch, you can do a reboot once you are all down doing all your uninstalls.
  • n8wrl
    n8wrl Member ✭✭
    Will it ask me about VSP? Right now I'm looking at a dialog that says
    "Are you sure you want to completely remove SmartSDR and all of its components?"
    Is VSP in "all of its components?"
    I'm reluctant to say Yes because I'm not sure it will ask me later...
  • n8wrl
    n8wrl Member ✭✭
    Great stuff Mike - thank you so much!
    -Brian n8wrl
