FRStackWeb Api Usage
I am running a Node-RED server and use FRStackWebApi to monitor the radio/client status for several years now. I have acquired another Flex radio and I was hoping some one that has used the FRStackWeb api and could provide insights on how they use the FRStackWeb Api for multiple radios. I have a need to show the status / environment for both radios simultaneously.
I have tried it using a single instance and also 2 instances of FRStackWebApi. I have not figured out how to isolate an instance to a radio. I have also not see much info on why you need to use multiple instances (possibly to control multiple slices).
At this point I am curious to why you would use multiple instances if you cant isolate an instance to a radio.
If anyone has used the api to see both radios on the network at the same time I appreciate your insights .
Thanks in advance
Hi Mick,
I only have one radio so no help.
Check with Alan, WA9WUD. He has a flow for two radios and I believe a MultiFlex one as well.
73 Dave wo2x
Thanks Dave.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
