FRStackWeb Api Usage
I am running a Node-RED server and use FRStackWebApi to monitor the radio/client status for several years now. I have acquired another Flex radio and I was hoping some one that has used the FRStackWeb api and could provide insights on how they use the FRStackWeb Api for multiple radios. I have a need to show the status / environment for both radios simultaneously.
I have tried it using a single instance and also 2 instances of FRStackWebApi. I have not figured out how to isolate an instance to a radio. I have also not see much info on why you need to use multiple instances (possibly to control multiple slices).
At this point I am curious to why you would use multiple instances if you cant isolate an instance to a radio.
If anyone has used the api to see both radios on the network at the same time I appreciate your insights .
Thanks in advance
  • David Decoons, wo2x
    Hi Mick,
    I only have one radio so no help.
    Check with Alan, WA9WUD. He has a flow for two radios and I believe a MultiFlex one as well.
    73 Dave wo2x
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    Thanks Dave.
