Flex 6400 USB Cable to Bandmaster III
Rod w7zrc
The following is from the Documentation page 18. Also referencing thread 7709481:
I think the diagram refers to the cable that goes between the 6400 and the Bandmaster. When I look up the cable (FTDI C232HM (MPSSE) it has a USB A connection on one end and individual pin connectors (female) on the other end. I assume the cable USB A end goes to the 6400. Where do the female pins on the cable connect on the Bandmaster?
Thanks and 73, Rod/w7zrc
Hi Rod
You will a an FTDI / RS232 adapter that will plug into the back of the radio. From there, I 'think' you'll need a double mail DB9 Null modem adapter.
That cable might work, but you need to check if it requires a Null modem adapter which swaps pins 2 and 3. You can give that a try and it works, great. If not, insert a null modem adapter.
FlexRadio uses Kenwood CAT commands.
Upon further research, would this cable work directly plugging into the 6400 and the Bandmaster II:
https://www.amazon.com/Adapter-Chipset-CableCreation-Converter-Windows/dp/B075YFS64T/ref=sr_1_4?crid=1575HH8NVV9YB&keywords=CableCreation%2BUSB%2Bto%2BRS232%2BCable%2B(FTDI%2BChipset)%2C%2B3%2BFeet%2BRS-232%2BFemale%2BDB9%2BSerial%2BConverter%2BCable%2Bfor%2BWindows%2B10&qid=1702927549&s=industrial&sprefix=cablecreation%2Busb%2Bto%2Brs232%2Bcable%2Bftdi%2Bchipset%2B%2C%2B3%2Bfeet%2Brs-232%2Bfemale%2Bdb9%2Bserial%2Bconverter%2Bcable%2Bfor%2Bwindows%2B10%2Cindustrial%2C202&sr=1-4&th=10 -
Thanks Mike. I’ll check out the null adapter. 73 and Happy Holidays. Rod1
Tried the USB to Female Serial cable between the Bandmaster III and the 6400 both with and without a null modem adapter and neither worked. I've gone over the documentation a few more times (old age keeps it from getting thru to the old brain) and it looks to me like I do need the C232HM cable as the Flex docs indicate. My first question about where that cable connects to the Bandmaster III would now appear to be the db9 connector on the Bandmaster. Each of the C232HM female wire ends may plug onto each of the indicated pins on the db9 connector on the Bandmaster. So now I'll order a cable and give it a try.
If anyone has any experience with this same setup, please let me know - Thanks and 73, Rod w7zrc0 -
Mike - does Flex have this cable in stock that I may purchase? If so, could you provide a link? Thanks!0
All - with help from John K9EL, I connected the FTDI USB to rs232 female cable (above Amazon link) between the BandMaster III and my 6400. I set the BandMaster for CAT; Kenwood; 9600-8-N-1; and the USB settings in SSDR for the same and it works fine. Thanks John and Mike for the help. 73, Rod/w7zrc
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
