DAX driver error version 3.5.9 new PC Windows 11
hi guys
I bought a new laptop it comes with windows 11
now Smart SDR with Driver problems
DAX seems not to install the Audio Drivers
and when you put the mic on the pc the program closes I already did
everything I found in the forum, I leave you some screenshots of my screen
thank you
N4RAG
Thanks for the Solution, Nobody Answered But Can Solve the Problem 73"
Can you check the sound control panels?
Both the PLAYBACK and RECORDING should show the DAX channels are not being used as any default system device. This especially goes for the RESERVED DAX channels.
At this station, having a default device (LINE-IN and SPEAKERS) in my particular circumstance made for easier Windows 10 upgrades.
Another helpful concept after an OS upgrade the sound panel is brought up and the PLAYBACK and RECORDING panels are examined. Often after the upgrade a machine check (BSOD / Core Dump) occurs when accessing the RECORDING. Since SmartSDR was not active, it suffers no corruption.
Best Regards,
_..--
Tim - k3Tim/7
Thanks Tim for responding, the problem was in Windows 11, I bought a new laptop and installed the Smart SDR as I always do
but what happened, I got that error, which I posted at the top of this post, so I started reading a little about the problem and found the answer
but it was too late because I had already installed the smart sdr without deactivating it
Core Isolation and this was octaculating the DAX drivers
but the problem was that it uninstalled the Smar SDR and the Core Installation
It stayed with the drivers used by the DAX, blocking them, it didn't matter that I uninstalled the Smart SDR. To fix the problem, I had to restore the new Windows and before installing the Smart SDR, I deactivated the Core Insutation, where is it?
Memory Integrity so I could solve my problem, I hope
May this help someone else 73
- 369 Community Topics
- 628 The Flea Market
- 85 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 244 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
