How to make CWX entries stick?
I'm not understanding how the entries in the CWX hot key messages are stored.
I've read in the manual that they are stored in Global Profiles but that does not work for me. Previously stored messages remain after I make a change and save the Global Profile.
For example: 10M CW Global Profile F1 message is AB6BT AB6BT (call 2 times). I change it to AB6BT (call one time) and save the profile. Then I select another Global Profile. Then I select the 10M CW Global Profile again and the F1 message reverts to AB6BT AB6BT (call 2 times).
Edit: There are CWX entries for SSB Global Profiles as well(?). I tried deleting CWX entries from all Global Profiles and they still remain. It seems random but...
What am I missing?
No clues out there???
Hi Geoff, mine seem to be there regardless of profile, but I don't use them, so I probably wouldn't notice...
I would submit a help desk ticket at this point.
Hi Len, I don't use CWX as a rule, but I was looking at how it worked and I can't figure out the way it stores text entries.
It's not a big deal but it bugs me...
Hi Geoff
Try this:
- Go to Setup in CWX
- Type your message in
- Hit Enter
- Do the same for any other messages and make sure you hit entire
- Save your Global profile
- Shutdown SSDR and restart it.
- See if the message is there.
Hi Mike, I'll try that. I tried to delete the entries in all my profiles but they kept reappearing.
I can't make them go away.
I did not try shutting Down SSDR and restarting.
Would I have to restart after each deletion?
You should not have to restart after each deletion unless you have save it in a profile and didn't resave the profile.
You'll need to describe each step to fully see what you are doing. Either you are missing a step or a radio reset might need to be executed.
Thanks Mike. I'll try to test it this evening.
Mike---I was successful in deleting all the CWX entries. I'm not sure what I did differently this time.
Now I'll try to enter some text in the hot key setup and see if I can asssociate with a particular global profile with out it showing up in the others.
That was part of the mystery; there were CWX entries in SSB profiles and FT8 profiles that I never entered.
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
