CW Skimmer Setup with Slice Master
Good Evening,
I have Slice Master installed and also the IQ Stream for Slice A in DAX. When I bring up CW Skimmer, but it will not show the frequency that is on my 6400M. I have been looking for something written that would tell me the settings within CW Skimmer for it to communicate with my 6400M. Also, what settings are necessary for Slice Master. I also know that I could use SDR Bridge. Can anyone offer any advice on where I can find a document that will help me to set this up?
Thanks!
Mark Griffin, KB3Z
I just activated SDR Bridge, and now CW Skimmer gives me the frequency that is on the radio. Plus the spots are showing up on the screen of my 6400M. Why is this working in SDR Bridge, but Slice Master doesn't for some reason?
Mark Griffin, KB3Z
Are you maybe bringing up CW Skimmer manually? In Slice Master, set it to launch Skimmer on mode. When you put the radio in CW, SM will launch Skimmer with the correct settings including frequency. When you leave CW, SM will close the instance(s) of Skimmer.
Erik,
I was told the Slice Master would be the better choice. Once I bring up Slice Master CW Skimmer automatically uses the right settings. And I did set it to start on mode. Thanks for the advice. I had great results with my 6400M with the ARRL DX CW Contest this past weekend.
Mark KB3Z
I setup CW Skimmer using SDR Bridge and it works fine. When I try to use SliceMaster with it set to start CW Skimmer on "mode", CW Skimmer starts up, displays "-12.00" in the display windows and then shuts down. I am not sure what needs to be done to get SliceMaster working with CW Skimmer. The IQ stream is active. It is like CW Skimmer through SliceMaster does not see the IQ Stream.
Don - kx9q
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
