How to connect A/B Switches to 2 AG's (16 antennas to 2 radios configuration)
Frank ON9CC
Hi all,
I have 2 AG's (so 2x 8x2AG) and want to connect them to my Flex-6600 for being able to switch between 16 antennas. I have configured both the AG's as mentioned in the manual.
I also have 2 A/B-switches and 1 SSC-OM-Module ( the OM Module is [u]connected to the Master AG[/u] with the supplied serial cable).
The manual doesn't explain however how to connect both of the A/B switches in order to use the 16 antenna ports by the 2 radio ports.
Questions:
- do I need to select '2xAG with OM control' in the AG configuration for what I'm trying to do? I assume yes, because if I do select this in the configuration and then select any of the Antenna ports (1-16), than the matching port number output on the SSC OM Module will also be selected. So if Radio 1 port uses AG port 1 and Radio 2 port uses AG port 10, then the SSC Output 1 and Output 10 LED (actually it's port 2 output 2 LED) on the SSC OM Module will be on.
But does this mean that I connect each of the 6 outputs of Port 2A to one of the A/B switch and each of the 6 Port 2B outputs to the other A/B switch (so run 6 wires in parallel to each of the A/B switches)?
Obviously I don't need to connect Port 1A and Port 1B to any of the A/B swithes since the A/B switch is N/C to Out A, so I only need to tell the A/B switches if they need to route the RF signal to the second AG.
I can see the logic here, but just want to check if I'm not shorting anything and damaging the SSC OM since I'd be running port SSC-OM outputs in parallel to the A/B switch.
Any tips / confirmation?
Thanks in advance!
Frank
ON9CC
NB: also posted the same question on the 4O3A forum but it seems to take a while for the moderator to review my question ...
Questions:
Thanks in advance!
Frank
ON9CC
I received this for 403a as I had the same question. If only using the two 8x2 AG's, there is no need for the OM.
Hope this helps.
Randy
Frank
Email 4O3A directly. They can talk you through it.
> Hope this helps.
> Randy
Hi Randy !
Thanks, this is what I was looking for ! ... and kinda overlooked in the manual TBH :/ ... also I had both units lying on my workbench and was only looking at the bottom side of them, so I didn't even see that A/B switch connector on top ... guess I had been running low on caffeine ... anyway, it could have been mentioned clearer in the manual at the back, where they explained the master-5lave configuration and adding the picture you attached would have been perfect.
Thanks again!
Frank
ON9CC0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
