Flex Meter V1.2
Is there a way to change the dial? I have one meter set to TX FWDPWR and it reads 0 - 50W.
Is there a way to change it to 0 - 100W?
JoAnn
AB8YZ
It seems not. You could ask the author W3XY denley@barnette.com
He has not updated it for some years though.
The meter scale for TX FWDPWR is 0 to 50 dBm not watts. 50 dBm = 100 watts. The radio sets the range for the meter scales.
Denley W3XY
The TX FWDPWR range actually goes to 53 dBm which is 200 watts. If you click on Snapshot in the menu you can see the ranges for every meter function as well as the current measurement values.
JoAnne - The FRStack meter window is another option. It can be transparent or not, horizontal or vertical. It displays a range of data.
JoAnn - another possibility for a meter is to enable the Meter View in FRStack.
Or in horizontal and transparent mode
Tnx to all for your comments. I do have the FRStack3 Meter too.
JoAnn
AB8YZ
