2nd Headfone for 6400M
Hello, I use the headset HEIL Pro 7 with my 6400M. Now I want to split the headfone audio, so that I can use the Pro 7 and another headfone same time. I tried a stereo Y-Cable, but there is only one side of the Y-Cable active.
Does some one have a solution?
Thanks in advcace - Detlef
I think you might get into problems with headphone impedance being too low if you use a Y-cable. I think a better suggestion (albeit more expensive) would be a multi-channel audio mixer.
Hi Detlef, my guess is that your Y cable splits the left and right channels into two mono channels (L on one connector, R on the other). A true stereo to stereo Y cable should work better.
That being said, Don's comments above are really the best answer.
Hello Don and Len,
thanks for your answers. I used a stereo Y-Cable. But the better way is to use an headfone splitter.
I bought one from fosiaudio with 1 Input and 4 Outputs and volume control for each output. The unit works fine. My impression is an general audio improvement. Not bad for an 40 Euro device.
Thank you again.
73 de Detlef - DK6OR
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
