2nd Headfone for 6400M
Hello, I use the headset HEIL Pro 7 with my 6400M. Now I want to split the headfone audio, so that I can use the Pro 7 and another headfone same time. I tried a stereo Y-Cable, but there is only one side of the Y-Cable active.
Does some one have a solution?
Thanks in advcace - Detlef
  • VE7ATJ_Don
    VE7ATJ_Don ✭✭✭✭
    I think you might get into problems with headphone impedance being too low if you use a Y-cable. I think a better suggestion (albeit more expensive) would be a multi-channel audio mixer.
    KD0RC Moderator
    Hi Detlef, my guess is that your Y cable splits the left and right channels into two mono channels (L on one connector, R on the other). A true stereo to stereo Y cable should work better.
    That being said, Don's comments above are really the best answer.
  • Detlef
    Hello Don and Len,
    thanks for your answers. I used a stereo Y-Cable. But the better way is to use an headfone splitter.
    I bought one from fosiaudio with 1 Input and 4 Outputs and volume control for each output. The unit works fine. My impression is an general audio improvement. Not bad for an 40 Euro device.
    Thank you again.
    73 de Detlef - DK6OR
