Using SmartSDR with a Maestro
If you use a Flex Maestro do you still need to run SmartSDR on a PC for using WSJT-X or N1MM or any other software for digital modes.
I tried now on the 6400 to open only SmartSDR CAT and DAX, but then it doesn't work.
So i think even with a Maestro you need to run SmartSDR, but maybe there is an other solution.
And is this with a M model also to need the hole SmartSDR package.
If you are using a Maestro as your Graphical Interface Client, no need to also run Smart SDR on a PC for WSJT-X, or N1MM.
But....on the PC, you must run Flex DAX and Flex CAT. Configure DAX and CAT to bind to the Maestro Client. You should see the client list in a pull down, following connection to the desired Flex Radio.
Alan. WA9WUD
Alan,
If using SSDR for Mac as the client instead of a Maestro, will DAX and CAT running on a PC with N1MM still bind to the Mac?
Randy
KH6XX
Yes. Mac SDR will show up in Windows DAX and CAT client pull-down selectors.
Alan. wA9WUD
- 391 Community Topics
- 665 The Flea Market
- 170 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
