How to set the ALC for digital modes
Maurice
Maurice Member ✭✭
edited October 2023 in DAX
How to set the ALC to use for FT4/8 or other digital modes.
On any other brand the ALC must be around 0, but on the flex it's diffrent or not?
Now for FT4/8 it stands around -10db is this good or to high.
  • Erik Carling EI4KF
    This is the level I have always used.
    Set it to about -5db. You can do this using DAX.
  • David Decoons, wo2x
    I’ve found DAX TX @ level of 48 should put TX level right at zero but peak indicator will show yellow and not red. If you see the peak indicator hitting red then it is too high.
  • N9OK
    N9OK Member
    edited January 2025
    I wish I could delete what I originally asked here but there is no delete button. Move along, nothing to see here... :)
