N1MM SO2R WSJT question
I set today N1MM to run WSJT on 2 Slices and tested OK on both. When I run WSJT on 2 bands, QSO automatically entering to the log. However I cannot figure out how to check I had a QSO with station of interest before QSO. Call sign appear in the "Check Log" after QSO completed.
Does anyone has N1MM running as everyday log in SO2R configuration and can share their experience in WSJT? "Check Log" shows Call sign in CW or SSB on both Receivers, it just not working in WSJT before I make QSO.
Sergey
OK, I figured it out with that youtube video - https://www.youtube.com/watch?v=rGiBos2Y85o
Decode list should be open for each Slice and when you click on the call from the list the call sign will go to the "Check Log" window. Pretty cool, however it only works for the station who is CQ-ing.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
