PGXL and the interconnect issue
Bill Levy
Member ✭
I had the problem here today. Trying to connect a 6600 to a KPA1500. No transmit on PTT or Vox and the RCAx2 was connected. Solution I got rid of 3.5.9 and went back to 3.4.23 and voila. The problem is WINDOWS and our versions we use and FLEX and the versions they use. So in future I will keep the Setup for my old software just in case....and this time I was lucky. Warmest regards to all, Bill N2WL
If RCA2 is not working, please open a support ticket. It might be a very simple fix as a radio database reset.
I can 100% confirm that TX2 does work as I use it every day on 3.5.9.
You can continue to use 3.4.23 but it will not work on SmartLink at all.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
