6600M: Assign internal keyer to computer client?
N1MM keys the radio just fine from the computer client, but the keyer is keying the Maestro client.
I am not finding help in the User Guide.
Chuck
de NJ6D / N7KU
Hi Chuck, I am not sure if you can do that or not, but there is another route to take.
When you have the front panel (Maestro) and SmartSDR running simultaneously, you go into MultiFlex mode, and each client operates the rig independently. If you put the front panel into SmartControl mode, everything will operate from SmartSDR, including the keying, mic, PTT etc. The front panel controls will be in sync with SmartSDR and will allow you to use either to change settings on the rig. This is the best of both worlds - the large display and mouse/keyboard controls of SmartSDR along with the physical knobs and buttons of the front panel. When in SmartControl, you don't get a panadapter on the front panel.
You set up one CAT channel for the Winkeyer emulation and then give N1MM the COm number assigned to that channel.
- 349 Community Topics
- 615 The Flea Market
- 8K Software
- 2 SmartSDR+
- 6.3K SmartSDR for Windows
- 411 SmartSDR for Mac
- 267 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 206 FLEX-8000 Signature Series
- 920 Maestro
- 893 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 138 Contesting
- 754 Peripherals & Station Integration
- 973 Third-Party Software
