TX Band Settings Backup
Every time I complete a Flex update, I always recall my just-saved profiles. However, the next time I try to use my amplifier, it doesn't work! The little TX1 check boxes in the TX Band Settings are all blank, and the power levels are all back to the default...gotcha! Gets me every time! So, I have to go in and reconstruct all my settings.
Am I doing something wrong, or is the TX Band Settings box NOT saved during a Profile backup? If not, could this be added to future improvements? And while we're at it, could we have the power levels in the box stay where we set 'em (and not change with subsequent RF Power adjustments)?
Hi Jim, the TX Band settings are saved in the Transmit Profile. That transmit profile is then saved with whatever Global profile that you have set. Check each Transmit Profile, and I think that you will find your previously set band settings. I also set my Default Transmit Profile the way I want it so that I have a second copy.
I use DDUtil to keep track of my power settings for use with my KPA 500 amp. If you have a DDUtil supported amp, this is a great way to go. It automagically changes the Flex output power to the saved value whenever the amp is changed from standby to operate. Here is a shot of the DDUtil Setup screen:
Thanks Len...I'll check all of this out!
--jim
Len: My problem was that I never established a separate Transmit profile...I always used the Default. I'm guessing that the Default is hard-coded, and any changes I made went away when I did a backup/recall.
Making a new Transmit Profile solved this...thanks for the clue!
--jim KJ3P
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
