v3.5.9 - Cannot transmit after update
Mike Geitner
K9MWG
Thanks, yes all are correct.0
Hi Mike, can you do a screenshot of SmartSDR? Do you have the TX indicator showing with a red background? Also, check to be sure that the PTT Inhibit box is not checked in the TX Band Settings screen for the band that you are operating on.
Yes, the TX settings are correct (not checked), the TX indicator is red. Oddly enough, the MOX button works.
Mike0 -
Ah... I would suspect the footswitch. Check to be sure that it is plugged into the PTT jack and that it is all the way in. If that is not it, use an ohm meter to test the switch.
Unplugged footswitch from PTT RCA and plugged in hand mike. No change.
Tested footswitch with Ohm meter. Functions correctly.
Yesterday, I reverted back to the previous version of SmartSDR and everything worked again.
This morning, I could not use it because I think Flex made it unusable or kicked me off, so I installed
3.5.9 again and the problem came back.
I'll revert back again right now and try it again.
K9MWG0 -
Reverting back to 3.3.29 works.
K9MWG0 -
Hi Mike, I would submit a helpdesk ticket. Older versions put you at risk of SD card issues and SmartLink problems (even if you aren't operating remotely).
I put in a ticket yesterday. Thanks!
K9MWG0 -
Update:
Tried re-installing v3.5.9 and then performing a factory reset. It did not work.
Hi Mike, I just thought of one other thing to check. Go to Settings, multiFLEX, and see if this is what you get:
Or do you get something like this:
In the second case, I fired up my TeensyMaestro in GUI Client mode to simulate an additional SmartSDR or Maestro connection to the same radio.
If your desired station does not have the LOCAL PTT checked, this could be your issue. There will be an Enable button on this screen if the other station has the local PTT. It doesn't show in my example because it is already selected.
From section 21 of the SmartSDR Software User Guide:
Thanks Len, I'll try that this afternoon!
Mike, K9MWG
Len,
I tried what you suggested, but that wasn't the problem. Back to the old version.....................
Mike K9MWG
Hi Mike
This is likely a configuration issue and if you open a support ticket, Ken will get you sorted out.
You might want to try resetting the radio as you will have to reset the radio if you downgrade to the previous version. You can do that if you don't want to open a support ticket.
Doing a downgrade and not resetting the radio may cause undesirable results due to internal changes.
Thanks Mike!
Yes, did all the factory resetting, etc. I can turn the problem on and off with the new version -vs- the last version. I opened a support ticket last week Sunday.
Mike - K9MWG
Follow up:
Ken at Flex responded to my support ticket two days after I opened it. I was watching my email instead of checking support online so I missed it. Ken explained that being able to use the PC MIC and a hardware PTT (foot switch) together was actually a bug that was corrected in the latest version of SmartSDR. Evidently, Flex never thought that someone would operate this way, sitting right next to the radio, considering latency between the PC MIC / PC and Flex. Well, I never really noticed it and was quite happy that it worked. I had both hands free for contesting, not having to mouse click the MOX button.
I would like to encourage the good folks at Flex to enable this functionality because it makes the FlexRadio even more flexible.
Mike K9MWG
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
