When I key the mic I get a message "Transmit slice has not been selected"
Hello. When I key the mic I get a message "Transmit slice has not been selected"
Here a video I made: https://youtu.be/oT_Yj-PFQBs?si=O3tYpyaJlhB4qXsN
Thank you.
Click 'TX' in the Slice flag to enable and allow transmission on that Slice - it will change from the greyed out state to red.
If i remember well, a few power cycles and restarts of smartsdr cleared that here...
Appears randomly, but seldom.
You asked this same question on August 15th. I answered it then and it is as Erik stated as well.
Is this a different problem?
Well why is it that I have to click on the TX flag ? Most of the time I launch Smart SDR and transmit I have no issues.
Transmit on the relevant Slice will stay enabled in normal operation. I have never had a transmit fail issue except after installing 3.5.9 when I did have to manually re-enable TX on the active Slice. If your Slice is deactivating TX there is something going on which, without knowing what if anything you have as clients and/or what activities you engage in with SSDR, we cannot diagnose.
I got it going I thank everyone for the help.
How did you resolve this?
It could really help others with the same issue if you let us know what you did to fix the problem.
I wish everyone would post the solution they find to their problem...
I clicked on the TX "Flag" Between the Split and the A on the slice menu. The question is how did it get turned off in the first place ? Was it the upgrade to version 3.5.9 ? But that was the way I corrected the problem.
Thank you.
My 19 Sept answer to you shows that the installation of 3.5.9 was the cause of this for me.
Thank you.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
