6300 Smart SDR v3.5.9 question
Hawk75
Member ✭
Searched quite a bit but can't really locate an answer... When I fire up the 6300 and launch Smart SDR, the software says it can't find a radio.
So far, shutting down rig removing power from it then restarting my computer has worked. Sometimes it takes a couple restarts to work. I'm not using Smartlink.
Any ideas on what may be the issue would be appreciated. Thank You!
-Andy
-Andy
What Windows Version are you using ?
How is your network set up ?
I use ours ( network via WIFI link ) daily with no issues, als some guy a hundred miles away, tests smartlink every day. No issues at present.
Windows 11 and wired network0
Hi Andy, try resetting your router. If that doesn't work, you should probably submit a help desk ticket.
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
