my flex 6400M has two ant ports 1 and 2 I need to know where in the radio these ports are connected
Best Answers
You can use both antenna ports for sending and /or receiving independently , Look at the your moving slice with frequency etc. There you see 2 times ANT1 ANT2 or RX ant . Choose this with the mouse. It will be remembered according to the band ( or your profile settings ) . Just understand you can and have to choose RX adn TX Ant each at its own. There is another way to switch antenna at the left side menu , I believe you can also find videos about that in youtube
Harry
DL9NDW
Ok Harry Thanks, Milo0
Milo...Were you able to look at the radio info in the hardware reference guide?
it is the missing manual.
Here it is
73 Dave wo2x
Why use the Maestro user guide rather than the 6400M/6600M user guide?
I thing the 6400M/6600M user’s guide would be more helpful.
Neil, Possibly, but Milo's original question was "where in the radio these ports are connected".
As far as using the 2 antenna ports, the SmartSDR-Software-User-Guide would probably be helpful as you suggest.
Neil and Geoff thank you both for you answers to my question. I would really like to aquire a 6400M/6600M users guide I have been trying to get one for most of the 2 years I have been trying to learn to use my 6400M if you can help me get a 6400M users manual it would be a big help and also tell me how to use this comunications link that would sure help too. Thank you Milo0
I posted a link to the hardware manual previously.
I got that from the Flex web site. The SmartSDR user guides are there as well.
I'm guessing that you are asking about SmartSDR. You don't mention what version you are running so here are links to versions 2 and 3:
Geoff I have smartSDR on my computer it is working ok I think I can conytol the radio from the computer
the uders guide I need is for the 6400M when I get that I should be able to setup the 6400M like I want it ok and get it to work I got a link to that users guide but was unable to download it I will have to try it again to get the 6400M working like it should I will be working on it soon as I get that users guide, thanks Geoff es 73. Milo-1 -
Hi Milo, Here is a link to the version 2 and 3 Maestro user's guides. The front panel of your 6400M is virtually the same as a Maestro in operation. Hopefully this helps.
I am using the 6400M/6600M users guide appears to be the one to use thanks.0
- 115 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
