my flex 6400M has two ant ports 1 and 2 I need to know where in the radio these ports are connected
and where I can switch them and what antennas I can connect to these ports, if there was a users manual I could find this info I think but I did not get one with my radio. Where can can I get this info please. Thank you Milo W9EK
Best Answers
  • Ha Gei
    Ha Gei Member ✭✭✭
    Answer ✓
    You can use both antenna ports for sending and /or receiving independently , Look at the your moving slice with frequency etc. There you see 2 times ANT1 ANT2 or RX ant . Choose this with the mouse. It will be remembered according to the band ( or your profile settings ) . Just understand you can and have to choose RX adn TX Ant each at its own. There is another way to switch antenna at the left side menu , I believe you can also find videos about that in youtube
    Harry
    DL9NDW
  • Milo
    Milo Member ✭✭
    Answer ✓
    Ok Harry Thanks, Milo
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    edited September 2023 Answer ✓
    Milo...Were you able to look at the radio info in the hardware reference guide?
    it is the missing manual.
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    Answer ✓
    Why use the Maestro user guide rather than the 6400M/6600M user guide?
