Installing Smart SDR
Hi after upgrading my HP Desktop PC running MS Windows 10 (All up to date and updated) to Smart SDR 3.5.9. And going through the install then cold boot. Everything is up and running on my HP Desktop. So I go over to my Dell G-3 running MS windows 11 (All up to date) and do an uninstall of version 3.5.8. When I go to install version 3.5.9 I get a stop dialog pop up that says setup/uninstall has stopped working. And I notice during the install the option for smart SDR is grayed out. What is going on ?
I recorded an video here : https://youtu.be/j8xclXyBA9o?si=9FgvI4bVWaixBf72
Thank you.
I had a similar problem on my Lenovo Windows 11 laptop. A quick google lead me to your youtube video.
I wasn't getting the 'stopped working' dialog box, but the installer would just close with no error message at the same point and not having installed anything. I remember this happening before with a previous version and found the fix in the forum:
https://community.flexradio.com/discussion/8024792/unable-to-install-smartsdr-v3-2-39-on-windows-10-laptop
Right-Click on the installer file.
Click on "Troubleshoot Compatibility"
Click on "Try Recommended Settings"
and follow the directions.
Chris
MM1PTT0 -
Yes that was weird. But your instructions worked. I read these instructions here: https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSDR-for-Windows-from-your-PC
I don't understand why Flex does not have some sort of cleanup program written when this happens.
I did get the Smart SDR version 3.5.9 installed on my Dell Laptop.
This fixed my problem too. Thanks Chris MM1PTT0
I had the same problem, that fixed it! Thanks!!!0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
